DS650 blown motor! Need help please! :)
Old Jul 28, 2010 | 01:39 PM
karloo512's Avatar
Default DS650 blown motor! Need help please! :)
Hi i have a ds650 and my piston just blew, is it alright to just change the piston and not change the timeing chain and all that? ive been told that just changing the piston might affect the rest of the motor after a while. When i opened the motor were the timing chain is everything looked as if it was new! I am confused as if i should be changing most of the motor or just the piston and piston rings?
Old Jul 28, 2010 | 02:55 PM
DSengineer's Avatar
Has been here a long time!
Never heard of having to replace the timing chain if a piston goes. You really need to pull the head off to see the extent of the damage. If the jug is heavily scored then it will take more than just a piston replacement to get it running again. You could also have valve damage but you wont know until you open it up.
Old Jul 28, 2010 | 11:32 PM
Big Ray 800's Avatar
Has a DS 800 Turbo Nitrous EFI money eating monster!
what do you mean by piston blew? Did it break? or just loose compression? ,
like DSengineer said you need to pull the head and see what happened check the valves to make sure they are not bent and check the head for straightness not warped then check the piston and rings . remember you have a plated cylinder so if you bore it you must replate it
Old Oct 20, 2010 | 11:29 PM
dubois4469's Avatar
Default head warped work
sorry for my english im frenchy but .. if your head is warped and you need to do a shaving job .. how much you cant shave before you need to change de natch on the piston (clearence) because a shave mind 13 millieme ( 0.013) i think or ( 0.0013) i dont no in english but i just want to know .. if i need to change my clearence on the piston ... thank you and sorry for my poor english ( ds 650 2001 engine )
Old Oct 21, 2010 | 06:53 AM
BasicBajaX's Avatar
Keeps busy in the garage building one thing or another.
As said in previous reply's...open the engine all the way up and go from there. It might be a good time to go with a 730...
Old Oct 28, 2010 | 06:27 PM
cucuy's Avatar
Default 730
So what kit do you recommend to do a 730???
Wouldnt mind doin it since my motor is apart for now!
Old Oct 29, 2010 | 06:46 AM
BasicBajaX's Avatar
There is someone on that goes by Goodsound. You might want to pm him, he had a used cylinder, piston etc...probably in great shape knowing him. These 730 kits are mostly all OMWracing kits. A well proven kit/engine builder...
Old Nov 2, 2010 | 07:51 AM
justme23005's Avatar
I have a used cylinder, head and piston
Old Nov 2, 2010 | 12:58 PM
cucuy's Avatar
Default 730 kit
GOODSOUND!! WERE ARE U????????
Old Nov 2, 2010 | 10:38 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
He can be found daily over at NMR.
EIF
Apr 20, 2017 07:15 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Whitelx1
Oct 2, 2015 10:55 PM
BYC
Sep 25, 2015 02:10 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
