creaky rear suspension!!!
anyone know how to silence the rear suspension in my 08 outty 650 max?
I've hit it with everything and all I (or anyone else) can hear in the trails is my damn suspension
I think it's coming from the big "torsion" bar (or whatever you call it) that allows the rear end to pivot up & down.
I don't see any grease fittings other then for the drive shaft.
I dont know if this will help at all but my 05 DS650 had the same problem, turned out that the top bolt on the shock was the culprit, all it took was loosening it maybe an 1/8 of a turn and no more squeaky. if it has lock nuts give that a try and see if maybe something was just overtightend when assembled.
no- it's not the shocks- it's the rear torsion arm. I'd have to remove the rubber caps to get to it.
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
