Pro Taper Bars
Old Dec 27, 2010 | 12:45 PM
yammimoose's Avatar
Default Pro Taper Bars
I just got a set for Christmas for my 2004 DS650. They look great but think think they are the wrong ones. They are too short.
What are the correct replacements for stock?
Do you need a different riser?
Should the bars be the same thickness?
Thanks
-Moose
Old Jan 19, 2011 | 12:02 PM
Todem's Avatar
Yes, you will need a riser. The DS has a funky bend which makes it hard to find bars that bolt right up without a riser. People buy bends that they think will work best for them so there really is no "correct" replacement. Plus when buying aftermarket bars people typically go to the larger diameter 1-1/8" bar so when you get risers make sure they are the correct dia. You will probably have to modify them as well because the steering stem holes are different. Most universal kits say they fit a DS but don't exactly.
Valder
Nov 28, 2020 07:38 AM
wendal
Sep 7, 2019 06:46 AM
badgerboy1
Sep 26, 2017 06:11 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
PrairieDog126
Sep 12, 2015 05:23 PM
