2000 ds650 neutral light wire
Old Mar 8, 2011 | 09:40 AM
remi_357's Avatar
Default 2000 ds650 neutral light wire
I just bought a 2000 ds650 and I'm trying to fix it up. The neutral light wire was grounded to the battery, so the light was always on. I read that the wire goes to a bolt by the oil filter. I cannot for the life of me find the correct spot to attach this wire. Could someone please post a pic of where the wire goes? Thanks in advance
Old Mar 8, 2011 | 10:56 AM
remi_357's Avatar
If someone could do this for me I have the service manual for 00-01 ds650 I can email you
Old Mar 8, 2011 | 07:23 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
Sorry I can't do a pic for you right now but if you look right in front of your oil filter and follow the wire down you will see where it is normally bolted. It is a small yellow wire with a black shield on it. If the wire is not there at all to follow then look to the front of the case guard and behind the stator cover. There will be two bolts very close together, one on the sprocket cover and one on the stator cover, a little bit higher than your brake pedal lever but below those two bolts. It's small and you may need a flashlight.
Let us know...
Welcome to the forums.
Old Mar 8, 2011 | 08:14 PM
remi_357's Avatar
Thank you so much. With that info I was able to find it. The wire wasn't hooked up, and the bolt to hold it was missing. Thanks again, all is good and working now.
Old Mar 8, 2011 | 08:37 PM
aceisback's Avatar
Military Rider
Congrats, glad I could be of some assistance. Anything else just ask, a bunch of us here have some understanding of these mighty machines.
Old Mar 8, 2011 | 08:48 PM
remi_357's Avatar
i appreiate it. this is my first atv so im trying to learn quickly. my first step is making everything work like it is suppose to
Old Mar 9, 2011 | 07:54 PM
infantryvet's Avatar
these things arent like lawn mowers where one normally doesnt change the oil or clean the air filter.they do require periodic maintenance,get yourself a manual,theres a lot of stuff to learn on these machines especially considering this is your first atv.y not a 250ex or polaris trail blazer for starters...lol
bzdok1234
30
Feb 23, 2016 01:55 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
tweeder
Jul 5, 2015 01:57 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
