ds 650 electrical issue
Old Mar 13, 2011 | 11:32 PM
dirtz564's Avatar
Default ds 650 electrical issue
I hava a 2000 ds650. Sometimes it will start sometimes it wont. When it does start it runs great for about 10 seconds then it dies just like you hit the kill switch. I can even hold the throttle about 4000 rpm and it just dies. Also it will backfire sometimes only when trying to start it makes me think im losing spark and then getting spark. Also ever since it was new sometimes when you would start the bike it would blow the intake boot off the carb or intake and die but it would only do it if you didnt hold the start button long enough. Also now when it wont start it sounds like something is broke (metal to metal thrashing sound) thinking its the starter against the flywheel not sure. I know its a lot to cover but i need help and from reading other threads i think i came to the right place
Old Mar 14, 2011 | 12:39 AM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
Welcome to the forum. Do a search on the fuel tank vent hose. Gets in a bind or pinched and prohibits fuel from reaching the carb. Start there then we'll visit the backfiring issue if it doesn't go away.
Old Mar 14, 2011 | 11:05 AM
dirtz564's Avatar
Thank you for the reply. Yes I checked the vent I even took the gas cap off. When it dies its sudden its not like I'm running out of gas. I cleaned the Carb it was pretty bad from sitting. I bought it new and only on its 2nd set of tires. Maybe 200 hrs on bike.
Old Mar 14, 2011 | 02:25 PM
chrisc321's Avatar
Pull off the air filter and spray some starting fluid in the intake. If it starts every time you try this then you have a fuel delivery issue. If it does not start with starting fluid then you have an ignition issue.
Old Mar 14, 2011 | 02:46 PM
dirtz564's Avatar
Good idea I'll try the starting fluid. Small amount of coarse.
Old Mar 14, 2011 | 05:37 PM
dirtz564's Avatar
Ok guys its definatly an electrical issue. I tried to start it up and it fired one time and that was all but it didn't start. I pulled the plugs to check for spark and it will only spark one time when you first hit the start button.I found a ground wire from the main frame to the crankcase that had been rubbed a little but not broken and not touching anything now but still only sparks one time then nothing.
Old Mar 14, 2011 | 09:01 PM
chrisc321's Avatar
Did you try using the starting fluid?
Old Mar 14, 2011 | 09:12 PM
dirtz564's Avatar
yes i did but it wouldnt even start tonight. plugs were wet and just one spark when i first hit the start button
Old Apr 18, 2011 | 10:17 PM
dirtz564's Avatar
its been a while but i figured out my problem. one of the nuts on the clutch sprag come off and got chewed up put a bunch of metal shavings on the trigger coil. now i got to figure out how to get the flywheel mag hub off. found a tool on the internet but alot of money. anyone know any tricks?
skinnyr6
Aug 25, 2023 02:18 AM
DeFox500
Jul 26, 2015 06:32 PM
Bratman2
Jul 23, 2015 12:36 PM
Unzzy66
Jul 11, 2015 10:01 PM
