stock carb mod question..snorkels
Old Mar 14, 2011 | 07:47 AM
chirochris's Avatar
Default stock carb mod question..snorkels
can i just cut the stock snorkels shorter to along side the carb rather than buy sump pump hose and start getting crazy and get a similiar effect..i have no clue how to do anything as many of you know..
Old Mar 14, 2011 | 03:54 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
Or just zip-tie them on the outside of the frame out of the way but not up under the tank cover...
Old Mar 14, 2011 | 11:53 PM
TheStir's Avatar
Started riding ATVs in 1974!
Here is how I ran mine for the best results when I was running a stock carb with the OMR mods. I think OMR had moving the tube deeper into the air box in his instructions.
You could do the same with the stock tubes.
Old Mar 15, 2011 | 07:47 AM
chirochris's Avatar
thanks for pic..ill try that..what do i do with the hose from crank case that connect to the left snorkel tube?
and the 2 black hoses that come off top of carb and come together to go under gas tank..read i should extend them down under carb or should i leave them?
Old Mar 15, 2011 | 06:10 PM
DSengineer's Avatar
Has been here a long time!
What is the effect of removing the tubes all together? My bro's DS has them removed and it seems to run pretty good.
Old Mar 18, 2011 | 07:46 AM
chirochris's Avatar
my understanding is with out tubes the air comes in with out direction and crashes into each other and you loose flow..so if you move tubes further back you control the flow from rear to front into filter with less disturbance ...therefore getting better performance...
Old Mar 20, 2011 | 10:43 AM
infantryvet's Avatar
these are basically street bike carbs,your only gonna be able to do so much with them.A cv carb has never came on a comp or high performance machine only play bikes like raptors predators and our ds.Kinda hard to polish a turd.
Cole Hadden
Jun 15, 2025 09:05 AM
Firefighter400
Oct 8, 2022 06:38 PM
GregM
Mar 6, 2018 06:53 AM
Reactant
Jul 16, 2015 10:29 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
