DS650 bottom end/mid range problems
Old Aug 21, 2011 | 09:39 PM
TroyBoy31's Avatar
So last week I had a chance to look at er again...
I had the choke on when it was idling, as it sat and idled, the idle got higher and higher, leaning out. Again, looked at the fuel line from the tank and nothing in it. I took the choke off and turned the petcock from "on" to "reserve", the fuel started to come into the line. Not filling it, but more so than the "on" position that's for sure... As mentioned before, when it would die WFO, it wouldn't start again until I moved it to "reserve", but it still ran the same when riding, with the bog/stumbling/coughing.
I'm stumped, is it possible something is wrong with the petcock? But what?? :S
Or is this a vent or vacuum problem?
Old Aug 22, 2011 | 03:53 PM
pipelayer's Avatar
I'm a Plumbing contractor and I have some old friends that always called me Pipelayer for some reason?
vacuum could be it check for cracks in intake rubber clamp or if the intake has the o rings in it then the snorkle tube for holes or hoses not hooked up. Also how is the clutch ?
Nondem
Feb 22, 2020 12:20 PM
clsharky
Jul 13, 2015 02:07 PM
rcappie4
Jul 10, 2015 04:54 PM
D-Hagz
Jul 4, 2015 02:19 AM
