2002 ds 90 2 stroke
Old Dec 12, 2011 | 02:40 PM
fop6fam's Avatar
Default 2002 ds 90 2 stroke
why do i have no spark cdi, stator, on/off switch etc.. were to start ??
Old Dec 12, 2011 | 03:12 PM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
Easiest place to start is the plug itself and the plug wire. Are you getting any power at all? The on/off switch kinda confuses me. If it's not working, then that may be your problem. Also fairly easy to check as well.
Old Dec 12, 2011 | 03:39 PM
fop6fam's Avatar
replaced plug no spark from wire at all there is no juice to the coil
Old Dec 12, 2011 | 04:04 PM
fop6fam's Avatar
how do i eliminate the run/stop switch as the problem , it also has a safty brake i guess a kind of nuetral safy switch the brake has to be engaged for the electric start to work and the engine turns over fine so i assume that the switch and safty brake are working fine
Old Dec 14, 2011 | 11:21 PM
fop6fam's Avatar
i guess nobody knows anything about these atv's i guess i'll part it out
Old Dec 15, 2011 | 08:14 AM
quadmechanic's Avatar
testing spark is hard to do in general. I had a the four stroke ds90 and it was a piece of crap. Never had any power so from the time I bought in new, to when I sold in last month, the tires still looked brand new. I don't know if your two stroke is the same way. I suggest you find a manual for the quad, they usually have wiring diagrams that can help you out.
Old Dec 15, 2011 | 11:33 AM
fop6fam's Avatar
ok thanks this has been a pretty good quad but being ten years old on my second rider i will probably let it go
Old Dec 15, 2011 | 11:50 AM
Supersock
Hired Gun!
I would think you could test the switch with an ohm meter.
I know there's a few more people here that have a whole lot more experience with the electrical systems than I do.
95wolv
Sep 27, 2024 12:00 PM
exmotocrosser
Sep 13, 2019 06:12 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
