DS650 rebuild help
Old Mar 15, 2012 | 05:19 PM
PhantomHalo's Avatar
Sorry its been a crazy month. Anyway, I put a new needle valve in the carb. The gas stopped leaking out of it but now I cant get it to start. Not too concerned with that just yet though. I changed the oil on it but have been reading a little bit more as to why my oil is milky. I read on another forum of the water pump impeller seal going bad. Could this really cause coolant to get into the oil? If so it would be a heck of a lot easier to change that to be on the safe side. Then I could worry about starting it up and seeing if I still get milky oil....Just dont want to start it up and waste all that oil for no reason. The guy said he changed the oil on it the night before I bought it from him. However it had been sitting since '09. I did change the oil reservior as well because it was collapsed in from the roll over. That should also take out any deposits or moisture from sitting. So now that I have a fresh slate to work with just looking for options!
Old Mar 15, 2012 | 07:53 PM
bartmann's Avatar
Banned
yea the water pump seal can go bad and leak coolant into the motor. you need the seals and the shaft. if you just do the seals it will leak..
Old Mar 15, 2012 | 08:45 PM
Awesome...more waiting!lol at least I know it's a possibility though! Thanks! I'll post more info when I get it changed.
Beeline08
Nov 11, 2016 04:00 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
CosmoM
Sep 21, 2015 04:57 PM
