where to start?
Yes parts are hard to find. Thye do not make th DS650 any more. I have buying most of mine on Ebay.
Ok update....I have ordered big gun cdi, billet aluminum exhaust tip, Dyno jet kit, and a 14 tooth front sproket. I also ordered a size 40 air jet for the Carb. I did the omr Carb mods. But I guess I'm wondering about jetting. Right now it has 165 main with the needle in 3rd groove from top. Air box open. Air screw out 3 turns. And ride at 7k ft. Any help?
Sounds like you're on your way. Mine is mostly stock and I have a 14 tooth and might go up to a 15. It will give you plenty of low end but than you will feel less top end. Maybe with the new cdi it won't matter but I feel like I'm hitting the rev limiter too quick. Been looking at the Ron Woods CDI myself.
#15
you will have drivability problems if you are not jetted close. popping, stumble, backfire, etc... You will probably have to jet up with your exhaust tip. I had to go from a 165 to a 175 with my DIY exhaust tip and the OMR mods, but I'm also at 1,100 feet.
Where did you buy the size 40 air jet? I need to get one as it runs a little lean at WOT.
#16
I got the jet at http://www.2wheelpros.com/search.html?q=traxter%20jet and it was $15 with shipping I put it in and it does richen it alot.
