Ds650 Overheat
Old May 23, 2012 | 09:30 AM
ds650 racer's Avatar
Default Ds650 Overheat
I just picked up a 2003 ds650 baja, the motor runs good. I took it out at night one time and i noticed that the exhaust pipes coming out of the cylinder were glowing red hot. What can be causing this? I have my air/fuel mixtures screw out 3 1/2 turns, i an not sure if the fan is turning on and off tho. Any help will be nice. Thanks you
Old May 29, 2012 | 08:06 AM
justme23005's Avatar
A red exhaust is usually caused by excess, unburned fuel in the exhaust. The first thing I would check, is the rubber diaphram on top of the carburetor. Make sure there aren't any holes in it. Also, Make sure the air filter and exhaust aren't plugged.
MRDS650
Feb 22, 2026 11:26 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
ScoobyDFW
Jun 13, 2000 11:33 AM
ScoobyDFW
Apr 10, 2000 06:52 PM
