Bent the left tie rod on my ds.
Old 08-06-2001 | 12:53 AM
99500scrambler's Avatar
I was out rideing this afternoon and I hit a water wash out that was abought a foot deep, and had square walls on it at abought 30 mph. At first I dident think I did anything to the machine and continued riding. Abought an hour later I stoped for a brake and noticed the tie rod had a slight bend in it. Should I replace them with stock units or is there any after market ones availible that would be better? Thanks for any info.
Old 08-06-2001 | 09:38 AM
DS650DAVE's Avatar
You can buy them a lttle cheaper than that.I bent rt.one.
Old 08-06-2001 | 10:42 AM
CALDS650's Avatar
The stock one bends for a reason, too keep from breaking other parts. If the tie rod was stronger the force that bent it will have to go some other place. On a trailside you can bend the stock one back and limp back home. With a stronger tie rod you might break the steering steam or break the wheel hub. Both are all most imposable to fix trailside with out a welder.
buddieboy
12-09-2016 06:50 PM
Roro
Ask the Editor
09-30-2015 11:58 AM
2many2ride
09-27-2015 05:35 AM
meddy0388
09-09-2015 07:41 AM
