Removal/Installation of DS fan....w/woods exhaust..?
Old Aug 26, 2001 | 05:41 PM
DS650DAVE's Avatar
A question......from "Lakota" The woods exhaust system is closer to fan than stock.While removing a "bad" fan some radiator fins were damaged.Before installing the fan and possibly damaging more fins whats the best way to create more space for fan installation?
***This question is being asked via our fellow DS rider "Lakota"***
Thanx for your input.
Hey Ron,.... buy a "PC" or something !!!!!!
Old Aug 26, 2001 | 10:11 PM
fourlix's Avatar
I too blew a fan, I think the early failure rate of these fans is because they are next to the header pipe. I got a second fan, a "pusher" which will fit in front of the radiator, with a big hole in the screen. It is one size larger than the stock rear fan, Spal Part #30100393 Off Road Warehouse
$72.99 included shipping. I have not made this modification yet.
If you are changing fans and pipe at the same time, be sure to change the fan while the pipe is off. It is a pain to change with the headpipe in place.
A good tool to straighten the tiny aluminum radiator slits is the flat, pointed end of plastic snap-ties we use to tie cables and oil lines and wires with.
Old Aug 27, 2001 | 12:54 AM
biggy's Avatar
putt wing nut,z on the fan ....they go out daily ......
SuzukiRevivR
Nov 4, 2013 07:52 PM
CobraGT40
Jun 10, 2013 05:02 AM
MiZZiE
Jan 16, 2011 08:24 AM
badger40
Nov 27, 2005 04:04 AM
tuffEnuf
Apr 15, 2005 12:19 PM
