After market rear sprocket
Old Oct 7, 2001 | 11:24 PM
sand45's Avatar
Who offers a after market rear sprocket? Dose knutz have any?
Old Oct 8, 2001 | 10:31 AM
CALDS650's Avatar
http://www.sidewindersprockets.com/ and http://www.sprocketspecialists.com/ make rear sprockets for the DS650
Old Oct 8, 2001 | 10:08 PM
VEGAS650's Avatar
Sidewinder. I have a 37 for sale if that's the dirrection you're heading.
Old Oct 8, 2001 | 10:33 PM
sand45's Avatar
Sorry but i want a 43 tooth. Thanks anyway!
Old Oct 8, 2001 | 10:37 PM
2000DS650's Avatar
As CalDS650 said Sprocket Specialist and SideWinder are the only two places I could find that had them to fit the DS. I have been told that a 41 is the largest that will fit on the rear without modifying the guide/guard...I have yet to install my 41 tooth from SideWinder. The front sprocket is much easier to change by the way. I just put on a 14 tooth a couple of weeks ago and with the stock rear tire size it is a lot easier to move slowly in the rough terrain in first gear now, plus I had to do something to compensate for the 23" sand paddle tires, the 15 tooth sprocket just didn't suit me.
Old Oct 8, 2001 | 10:55 PM
sand45's Avatar
2000ds650: Did the 14 tooth sprocket fit with the stock chain? Sprocket specialists can make you any size rear sprocket you want!The 43 tooth sprocket fits just like the stock one but, you have to use a 110 link chain.
Old Oct 13, 2001 | 11:37 PM
2000DS650's Avatar
Sand45,
Yes the stock chain fits fine. It was Sprocket Specialist that told me that a 41 tooth was the maximum size without modifications. You get almost the same effect with a 15/40 set up (2.667) as with going to a 16/43 (2.687) and the front sprocket is much easier to change.
Old Oct 13, 2001 | 11:55 PM
sand45's Avatar
I just finished installing the 43 tooth sprocket and 110 link chain.Every thing fits fine!I was not sure if the 14 tooth front would work with the stock chain.OOOHHH man if i would have know the 14 tooth worked fine.I could have saved some $$$$$ oh well live an learn!!!
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
Dammar
Aug 26, 2015 07:12 PM
rcappie4
Jul 10, 2015 04:54 PM
