GBC Sand Devils?
Old Mar 22, 2002 | 07:10 PM
sand45's Avatar
You cant go by the tire pressure listed on the side of any skat-trake tire.These tires are just caps they use to shave & mold the paddles on!
Old Mar 23, 2002 | 06:11 PM
hinglbyds's Avatar
Sand45,,, your right, I forgot they were other tires that were shaved. I apologize again. What do you normally run for tire press?
So how are we supposed to know the min/max pressure? When I received my new extreme's they were mounted on aluminum. There were no instructions or anything. Just the invoice.
So I go by my 25 years of experience with ATC, ATV and sand rails. Depending where we are riding I will run between 3 and 6 psi, whatever works the best. If the mfg dosn't re-label the tire for min psi they can't dispute a repair. If they ask what pressure I was running, "It was 5 psi".
Thanks for the info Sand45!
Old Mar 23, 2002 | 08:28 PM
sand45's Avatar
Skat-trak swore up & down that all extreme paddles come with a sticker lable saying the correct tire presure to run.Well mine never had no sticker! so i asumed it was the same as the regular haulers.So yes if you ever have trouble with your extremes definetly say you where running 5 psi[img]i/expressions/face-icon-small-wink.gif[/img]
black_thunder
Sep 20, 2015 10:21 PM
rawbdiggity
Sep 7, 2015 12:05 PM
lancemll88
Sep 5, 2015 03:16 AM
Jul 24, 2015 11:57 AM
