Need Traction Help In Sand
Old Mar 26, 2002 | 04:14 PM
BigJon's Avatar
What tire pressure are you running? That makes a huge difference for me.
Old Mar 27, 2002 | 01:53 AM
DuneRider1's Avatar
I got the tires brand new and they had 7psi in them. What do you run on your paddles?
Old Mar 27, 2002 | 10:52 AM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
20 IS SMALL but next time try 2nd gear take offs. with that little tire and you will notice a big difference since 20's lower your gear ratio so much. and i dont mean to bum you but it sounds like your clutch's are slippng at top speeds the only time my tires just start spining after 4th gear is when i hit my nitrous. oh i run 23 mags like jbomb 8,10,12s good luck!!
Old Mar 27, 2002 | 01:07 PM
BigJon's Avatar
I usually run about 3 in mine too. I weigh about 300 though. I am thinking of buying some 22" v paddles soon.
Old Mar 27, 2002 | 09:05 PM
  #15
mintychip's Avatar
I run 10 paddle haulers in 20x10x10 and I have no problems with traction. These are my first tires on 10 inch rims and I don't really notice a difference from my old 8 inch rims on my 250r. Air Pressure is THE MOST important variable in the sand, plus any adjustments are free so go experiment, have someone time you up s hill or see if you can pull a higher gear by adjusting your pressure.
Old Mar 28, 2002 | 05:13 PM
  #16
Hightower's Avatar
I run 20" 10 paddle haulers and I'm happy with them. They handle well just riding, which is what I do most, and when I hit the drag strip they perform well too. Its hard enough to keep the front down dragging, so I know I don't need any more traction. Then again I run 3-4 psi. If I had 7 psi in them I would never win anything.
One guy I met ran 10 paddle 22" haulers on his stock DS - more traction all right, he was unbeatable, but they sure weren't as much fun to ride around on.
I used to run Kenda Trakkers too, they were a blast to handle - cut donuts on the side of a sand wall awesome - but worthless to drag with, even with 3psi. It all just depends on what purpose you want the tire for.
Old Mar 29, 2002 | 11:17 AM
  #17
buttfungus's Avatar
I just ordered a pair of the new Maxxis Rooster v-paddles. They are 20x10x11 with diameter of 22" and 8 paddles-1" thick. I will let you know how they work out. They also have a nice looking straight paddle and front sand tire as well.
Maxxis website...
Click on products, atv and take a look at the new Rooster's.
Old Apr 2, 2002 | 06:29 PM
  #18
THEMOOSE's Avatar
I just ordered a set of 8 paddle 22 X 11 X 10 Extreme Haulers on 9" wide .160 rims. After borrowing several sets of paddles I decided that these were hands down the best tires for my type of riding, Sand drags, hillclimbing & dune running.
Sep 30, 2015 01:37 AM
black_thunder
Sep 20, 2015 10:21 PM
rawbdiggity
Sep 7, 2015 12:05 PM
lancemll88
Sep 5, 2015 03:16 AM
