k&n sn2550 saga..
Old 04-03-2002 | 02:20 PM
KenDS's Avatar
Hightower,
There is no "cutting" of the frame involved. You would simply attach the shim to the frame using the existing holes that are there, or if you prefer, using an adhesive such as foam servo tape or an epoxy or even clear silicone. The shim only acts as a spacer to increase the gap.
Old 04-03-2002 | 07:40 PM
Ledger's Avatar
I'm on my 3rd K&N on the carb. In hind site, I would get one in the air box with the lid off. If you ride MX or jump alot it's not worth the hassle.
Old 04-04-2002 | 12:53 AM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
hey ledger i have a spare one if you need it. you know how to contact me i bought it and it just did not seem to fit right. and with all i have in my bike im not chancing it.if you want it its yours no charge i tried to give it to bajapilot no dice.
Old 04-04-2002 | 10:47 AM
glamisds650's Avatar
pull the hoses out and use 1" pvc pipe caps to block the holes.
  #15
Old 04-04-2002 | 01:00 PM
fourlix's Avatar
We were riding up high a couple of weeks ago, about 9,000 ft. The DS was running kinda rough, like it was too rich. I popped the airbox lid off and, viola', perfect. Back home, at 4,000 ft. it was running pukey, too lean, put the airbox lid back on, and Bingo, right back where we started.
I have just ordered the clamp-on, but I think I will send it back. I already have the K&N with the outerwears that came on the stock filter.
Rejetting the DS is so easy, with allen head bowl screws that is.
I think I will just take the lid off and jet appropriately. I can always put the lid on if I go down in elevation, or rejet.[img]i/expressions/face-icon-small-cool.gif[/img]
  #16
Old 04-04-2002 | 01:16 PM
TheFasterTheBetter's Avatar
I did the same thing as Forlix. I am jetted for sea level went to Sand Mt. at 4000' and removed the air box lid and ran great.
I just bought a K&N carb mount but haven't taken it out of the plastic wrap yet. It appears to have a bend in it to where the filter would aim downward once mounted on the carb. Would this solve the problem? Could this be a new design? Do they all have this feature.
I may end up sending mine back as well. I don't wish to do all kinds of shimming.
Also had lead-time issue:
I ordered my K&N the same time I ordered a Woods CDI. Not sure what hapened but it should only take a day to UPS from Southern CA to Northern CA. I was charged on the 26th and it didn't show up until the 2nd of April. There was no problem with my address and I gave my phone number so, if something was on backorder I would have expected to have been told at the time of order or called later. If I had made trip plans for last weekend, I would have been very disappointed.
  #17
Old 04-04-2002 | 02:04 PM
KenDS's Avatar
A slight variation to Glamisds650's suggestion is to use a 1" brass or steel freeze plugs if you don't like white plastic.
  #18
Old 04-04-2002 | 06:40 PM
DSWOLF's Avatar
You guys wanna know what i think about this k&n saga,it doesn't matter what filter you have on it as long that it fits on the carb thats all that counts,and if it does sit on the frame an dents a little that doesn't matter either it's not gonna stop the flow of air going in actually i think it's better if it sit on the frame it holds the carb more stable,about the outerwear if you put a small piece of duck tape where it rubs it will fix your problem...
DSWOLF.
  #19
Old 04-05-2002 | 10:14 PM
Hightower's Avatar
1" pvc pipe caps are too small. You need 1-1/4" pipe caps - they measure the same 1-5/8" diameter as the snorkel tubes. Get schedule 80 PVC - its dark gray instead of white.
  #20
Old 04-05-2002 | 11:03 PM
1" pipe cap- not plug - is also 1 5/8" od. which slips into opening and you can't tell that they are there. i also double checked the size just to be sure.
