Ohtsu Sp Wamulass Sand/Mud Tires will it fit my ds650
4 on 115 will not fit the DS. I believe that is the honda rear wheel bolt pattern. The DS shares almost the same bolt pattern as the front Honda hubs, but the center of the hub is larger on the Bombardier, so the cut out on a Honda wheel will keep it from fitting. Unfortunatly, if it fit on anything else, it won't fit the DS.
09-30-2015 01:37 AM
