Why does my DS shutoff
<< HEY KODIAK you'll need to do some testing but i have seen many case when running ***** to the wall for long periods that the gas cap can not supply enough air to compensate for for consumption and cause a back up on fuel[prevention vented cap]and also on real good runners they have a miniscoule fuel outet you may have to drill your petcock jeff told me this one and it worked.later good luck hope this helps >>
Jeff are you telling all my sercets. Shoooo LOL
J Ross >>
Sorry man!! yes I let the cat outa da bag
Jeff
Kodiak01,
I had the same problem once with the stock carb right after I put the carb mount filter on,I forgot to put a breather on the end of the clear tube coming off the top off the carb (sucked in sand)caused the slide to stick every once and awhile,Good thing I had an extra carb...
Jeff
#15
For the stock tank breather hose - I drilled a 1/4 inch hole through the tank cover, just in front of the gas cap and ran the stock breather hose through it, under the bars, down beside the steering stem, and cut off the extra 3 feet that used to wrap around the tank. What a stupid design. Its just like having a vented cap now, but it didn't cost $50.
