Cutting of the plastics
What did you guys use to cut them with? I want to do this but don't want to screw it up. Also does anyone know where on the inet that you can buy an aftermarket rear piece? I would rather cut an after market one than the stock.
SandScum,
It wasn't to hard to mount the battery up front(if you can weld a little)
It was alot harder to move all the wiring starter relay etc.
I used the have it under the seat where the air box was(that was real clean),but had to relocate it again for the NOS bottle.
If you dont mind losing the air box,under the seat would be better(less weight tranfer)You figure after you add a lighter tail pipe and move the battery (up front)you are shifting a bit of weight to the front.
Jeff
Jeff
Sandscum,
I recently had to purchase the rear fender assembly and it was only $76 from my local dealer. I thought that was a great price, not nearly as much as i thought it'd be. FYI the front headlight surround piece was more expensive at nearly $90.
Yeah I'll have to have a beer before tackling this one. Although $76.00 isn't too bad for a new one if I really screw it up. I just wasn't sure what you guys used to cut it with. I like the looks of it, it looks sweet.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
