Serious inquiries needed on subject of Raptor vs. DS
You just couldn't stand that Ernie was getting more power could you!!
The way to make power is air flow.
I'd get a mild cam so you won't lose your bottom end, better quality springs, a good port job & a higher compression piston.
As long as you don't go too high on compression you'll get good HP gains with no loss of reliabilaty.
With what your going to spend on hop ups you could trade your DS for a Raptor!! J/K LMAO!!
Hey Hightower I hear you had probs with your coolant mixing. well I have I think the same prob. I was riding on day and my fan was on all the time so I checked to see if I had coolant and gone all of it. so I filled the radiator and the little tank and to my surprise half of the fluid in the radiator is gone. so I drained my oil to see if it was mixing in my oil and sure enough it was. but now my only prob is to find out what happened and how to fix it instead of driving to my dealer which is a 4 hour drive. can you help?
RticKwad
12
07-19-2015 12:22 AM
