Installing flywheel and magnetic rotor
Old Jul 21, 2002 | 07:06 PM
ScoobyDFW's Avatar
I am having trouble installing the flywheel and magnet rotor on the shaft. There is a key in the crankshaft. When I slide the flywheel and magnet rotor onto the shaft is comes to a hard stop a few millimeters short of flush and won't go on any further. Hammering doesn't have any affect. Using an impact wrench torquing the nut on doesn't have any affect, it is still not flush.
Do you have to heat the magnetic rotor up to get it on?
Do you have to set the key to a particular angle?
Old Jul 21, 2002 | 08:48 PM
dsmike's Avatar
put it on about a 1/4 inch foward from your key. then turn it backwarks and it will slip on. if your starter is off it makes it easier to turn the gears. if you still have problems give me a call.
Old Jul 21, 2002 | 09:23 PM
jeffnrivercity's Avatar
I have struggled with that too.....but if you keep playing with it,you will soon go on.
DSMike......that probably is the trick...just didn't relize what I did to get it on....
Old Jul 21, 2002 | 09:30 PM
dsmike's Avatar
jeff that is the trick for me. i have had it off alot. thats how i get it back on.
Joe454
Nov 20, 2020 01:19 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
2many2ride
Sep 27, 2015 04:35 AM
