how can i get pami cams?
Old Jul 28, 2002 | 09:30 PM
dsmike's Avatar
i went to the drags today and broke another cam. the only time the cam had been used. does anyone know if the pami cams are stronger or if they make a titanim cams? its starting to suck only getting to ride for a couple of passes.
Old Jul 28, 2002 | 10:29 PM
Hightower's Avatar
What kind of cams are breaking? I wanna make sure don't get them.
Old Jul 28, 2002 | 10:47 PM
dsmike's Avatar
i keep breaking the RWR A1 intake cam. i have a smaller cam that is a RWR 11 and it never breaks. i have broke 3 intake cams now.
Old Jul 28, 2002 | 11:02 PM
Rockey's Avatar
Did you miss a shift? How high of an rpm do you think you were at? It sounds like Mr piston and Mr valve became better aquainted. I had that happen several times in my 400hp 302. Since it was a pushrod engine the pushrod was the weakest(and cheapest) link. Although I did bend several valves as well. With Rotax's OHC design things must be different. The cams lobe profile also dictates how well things remain in contact at high rpm. That is probably why the smaller cam is fine. Im guessing you have the lighter reciprocating parts like titanium retainers and checked the spring seat pressure.
Old Jul 28, 2002 | 11:29 PM
dsmike's Avatar
i don't think it hits the piston. i think it would bend the value. it only breaks the outside lobe off. i checked piston to value clearence. i shift it at about 10-10,500.(i'm guessing)
Old Jul 29, 2002 | 12:03 AM
14mins's Avatar
DSmike- shift 5 rpm's sooner.[img]i/expressions/face-icon-small-happy.gif[/img] Are you running matched cams or 2 different profiles?
Old Jul 29, 2002 | 12:06 AM
mean650's Avatar
i bent my both exhaust valves by over reving.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
QuadRiders
Oct 22, 2015 04:13 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Canamaniac!
Sep 15, 2015 06:19 PM
