Which Extreme hauler to buy?
I have the 20x10x10 8 paddle regular hauler on mine and they work great. Bike revs nicely and throws a nice roost. Climbs easily. I would not hesitate to buy them again, but this time I would get the extremes like you said.
I have not rode with a 9 paddle, but it should work good also and maybe someone can give you more info on that.
Bat
Bat
I have the edges they work fine. Friend of mine has the extreme hauler with similar mods to me (pretty much stock). He got the 22x10x10 10paddle and makes a huge differnce. He has a two to three bike lead over me out of the hull. i would suggest the same tires. That is what im going to buy the next go around. From what i understand the more side wall you have the better floatation of the tire= better hook up. The bigger tire shouldn't hurt the top end real bad and should give more bottom end.
I run 20 20 10 8 paddle haulers and love them, im also geared down to 15t front sproket, its the perfect setup for me, i cant keep the front end down pulling through second(well i can when i try, you know) but they hook up real well, when i ordered mine the sales dude told me the taller haulers and extremes would be more likely to rip off on a DS cause its too much bite, but i think he did not know what he was talkin about, it says on skat's website the extreme's are for the big bikes so thats what i would buy if i ever wear out my haulers, but ive got many hours on them in real soft sand and i cant even wear off the rubber nipples, so they still look brand new.
jetjock16
jetjock16
I run the 8 paddle 22x11x10 Extremes. They are a great tire!
I wouldn't go with any more than an 8 paddle unless you have a tricked out DS or go with the 20" tires. I tried a set of 10 paddle 22X11X10 & the launch was great (but not much better than the 8 paddle) But they would suck a lot of power in the upper gears. I have no problems getting around with my Extremes & with the Mohawks on the front I have no problems turning.
Polaris Side by Sides
09-15-2015 03:33 AM
Elkaholic
09-06-2015 02:44 PM
