Using engine ice?
Old Aug 8, 2002 | 05:35 PM
DSaholic's Avatar
DI is distilled water. I will hopefully be able to tell you how this stuff works after the trip to St. Anthony's next weekend.
Old Aug 8, 2002 | 07:14 PM
Batoutahell's Avatar
I think DI is de-ionized water, I dont really know what the difference is, but thought that might help.
DSa, let us know how it works out for you. I might be looking into that.
bat
Old Aug 8, 2002 | 07:20 PM
smitty911's Avatar
Distilled water is water that has been processed to remove particles.
De-ionized water is further processed and remove any electricial charge. It's what alot of car washes use for "spot free rinse", If you can get this it would be the better of the two. Less stuff in the water= less stuff in your cooling system.
Smitty
Old Aug 8, 2002 | 07:31 PM
ThePunisher's Avatar
Where do you get De-ionized water?
Old Aug 8, 2002 | 07:50 PM
  #15
AZDUNNER's Avatar
Smitty is correct regarding the properties of DI vs Distilled.
Check your Yellow Pages under Water. Some water stores should carry it. I have also seen it in grocery stores on occasion.
Don't wrap yourself around the axle trying to find DI if it's not locally available.
Use Distilled if you can't find it. It won't make that much of a difference and may be somewhat less expensive.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
Jul 30, 2015 09:39 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
