CT 105mm big bore piston?
Old Oct 3, 2002 | 12:37 PM
  #31
Lightweight's Avatar
Blackhawk--Yeah that's what I was thinking too. Thanks for all the info guys.
Old Oct 3, 2002 | 01:18 PM
  #32
DuneMe's Avatar
Lightweight:
You can run pump gas with the 11.2:1 Pami or the 11.5:1 Wood Pistons.
Interesting that they say the cams, piston, porting will get as much as the bore.
I will be starting this work after the Oct 11-13 trip to Sand Mt.
-Mark
Old Oct 4, 2002 | 11:36 AM
  #33
Rockey's Avatar
<< mine is a ct 105mm liner. i dont think it is detonation. i only run c12 fuel. it always blows on the head side of the gasket. the cylinder side has the o-ring. the last time i changed it, i had a reciever groove cut in the head, a .020 thick copper o-ring, and a .020 spring steel gasket. this was the first time i didnt use a copper gasket. we finished it the night before labor day. took it to la. dunes labor day and it lasted 1 hour. i did find 1 shop who garentees they can make it seal, they say the machine the cylinder and head to use a steel sleeve, i think ? or something like that. but they charge 300.00 to do it. im not sure i wanna take a chance with the pain of pulling the motor out again ( without scratching my frame ) and spending 300.00 and hoping it seals. its not the money, id spend 5,6,700.00 whatever if i was SURE it would seal. >>
Does it blow in the same spot everytime? If so, Id double check the flatness of the head. I'm sure you've laid a straight edge on it and checked with feeler gauges. Did everything check out ok? Can you take some pics of the gasket after it is blown?
Old Oct 7, 2002 | 11:59 PM
  #34
badassbomb's Avatar
i dont know if it leaks in the same spot everytime? its hard to see where its leaking. i brought the head and cylinder to a machine shop and they checked it to see if it was straight. it was a few thousands off. they machined it straight. they said they dont see any reason why it shouldnt seal. i havent pulled the motor out yet since it blew labor day to see where it blew this time.
Old Oct 8, 2002 | 12:54 AM
  #35
SANDMAN430's Avatar
gary at tvi was telling me about some stronger head bolts that he is getting in, he was telling me that the stock ones aren't strong enough
Old Oct 8, 2002 | 12:59 AM
  #36
badassbomb's Avatar
ill take a set as soon as he has them. when should i call him?
Old Oct 8, 2002 | 01:01 AM
  #37
Hurycne's Avatar
Is he available for other parts? Do they have a website yet?
Old Oct 8, 2002 | 03:40 AM
  #38
SANDMAN430's Avatar
they have lots of other parts, gary seems to know a lot about the ds. i bought some clutch springs from him, they work great. he has cams pistons,nos, some kind of new head on the way, i think he said he even has a 760 motor. 503-648-1254
Old Oct 8, 2002 | 03:49 AM
  #39
SANDMAN430's Avatar
badass bomb that would be great, i,ve heard that the head bolts are a problem on the lt 500. so maybe that could be your problem. stretching was the problem. and that was what gary was telling me the problem with the ds. so maybe you could figure this out for the rest of us and then we could have 105 bore that run every weekend.
good luck.
Old Oct 8, 2002 | 04:23 AM
  #40
14mins's Avatar
Badassbomb- I hope you get that beast sealed up. Much to good looking to use as storage. Are you torguing to factory specs??? Good try on hte gas money[img]i/expressions/face-icon-small-happy.gif[/img] Things have gotten a lot faster since the last time. 686's are comon around here. LOL
