Bleed Brake system??
Old Nov 8, 2002 | 10:51 AM
Bom2000's Avatar
Default Bleed Brake system??
How do you do this I can't find my manual and my front brake lever has no pressure at all and it goes right to the handle bar. I am expecting there is air in there somewhere.
Old Nov 8, 2002 | 04:36 PM
Bom2000's Avatar
anyone??
Old Nov 8, 2002 | 05:54 PM
Scootter's Avatar
If u do not have a vaccum pump, then you have to do it manually which takes 2 people to do it effectively.
I would recommend a vaccum pump $30 or so.. With it you just hook it up create pressure, open the bleeder screw and presto the fluid comes out..
otherwise you need to alternately pump your lever while opening and closeing the screw. What u want to do is squeeze the lever while fluid comes out, then close screw before releasing. Let go of lever and repeat
Send me an email at brow0814@umn.edu if u are still hvain problems
speedbuff
13
Nov 11, 2020 10:16 AM
1ArmBandit
Sep 8, 2015 08:59 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
