Timing chain rattle?
Old Nov 10, 2002 | 05:34 PM
Gaskett's Avatar
Default Timing chain rattle?
I seem to hear an excessive amount of timing chain rattle. You don't hear it at all when the RPM's are up, but hear it quite abit when the RPM's are low.
Is this normal? and if not, is there a way to adjust it.
Thanks for any help.
Glenn
Old Nov 10, 2002 | 07:18 PM
Gaskett's Avatar
Is it an easy thing to check? Do I have to remove anything?
I saw a large bolt (plug) on the side of the tensioner on the cases, is that the place for checking?
Thanks,
Glenn
Old Nov 11, 2002 | 11:12 AM
Gaskett's Avatar
Har far does it compress?
I pulled mine out and it only compressed about a 1/16 or a little more.
Glenn
Old Nov 11, 2002 | 06:30 PM
Gaskett's Avatar
When I say "pulled it out" I meant I removed it (sorry for the mis-interpretation).
If the inner portion sticks out of the outer portion about 1/2" inches, then it wasn't collapsed.
When I tried pushing it in, it only moved 1/16th of an ich using light pressure, I guess I need to push harder to make it collapse.
Is some timing chain rattle normal on these machines?
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
Sjrpp
Jul 5, 2015 09:04 PM
