How he He!! do you get the stock Grips off!? !@#$#@
Old Nov 19, 2002 | 06:57 PM
OrganDonor's Avatar
Default How he He!! do you get the stock Grips off!? !@#$#@
I'm at the point that the right angle grinder is looking mighty nice! please help!
thanks
OrganDonor
Old Nov 19, 2002 | 07:02 PM
biggerisbetter's Avatar
Personally I changed the whole bars. I put 4" risers with "dog bones" on my DS and they feel,and look great!!!
But back to your question: I don't know.[img]i/expressions/face-icon-small-tongue.gif[/img]
Some say to stick a air nossle in one end, and the air pressure will seperate the grip from the bar.[img]i/expressions/face-icon-small-happy.gif[/img]
Biggerisbetter.
Old Nov 19, 2002 | 07:21 PM
DSjockey's Avatar
Take out the plug in the end of the grip and remove the screw then they should slide right off...them tricky canooks [img]i/expressions/face-icon-small-happy.gif[/img]
Old Nov 19, 2002 | 07:24 PM
eRAPTOID's Avatar
I'm not that familiar with the DS, but can't you just cut the old ones off if you don't want to save them?
That is what I did with my Rap the first time.
"TOID"
OrganDonor's Avatar
There not slipping! ?!@#@!$!!@!#@#!@#%#
Old Nov 19, 2002 | 07:28 PM
OrganDonor's Avatar
There is some kind of plastic under them! Do I need this plastic? Grinder time!
Old Nov 19, 2002 | 07:43 PM
Eaglecollector's Avatar
The way DSjockey said is the correct way. If you grind ort cut them off then you will be stuck with bars that are not kind to regular ATV grips.
Old Nov 19, 2002 | 07:51 PM
jeffnrivercity's Avatar
Did you try an air compresser......pressurize the bars,stick an air hose in one end..and your finger over the other end.........
Jeff
Old Nov 19, 2002 | 08:22 PM
RideRed420's Avatar
I would just cut them off.......
Old Nov 20, 2002 | 01:41 AM
Hurycne's Avatar
You are doing all that work making your bike look good and you are planning to use the ugly stock bars? Grab some tag bars and a handle bar riser from alba.
