45mm Carb ??
Old Dec 4, 2002 | 10:49 AM
SANDMAN430's Avatar
Default 45mm Carb ??
does it do it with piston cams, also or is it in stock form that the problem exist? and i think they are only 375 new, so no worry on the e-bay
Old Dec 4, 2002 | 02:18 PM
KenDS's Avatar
The accelerator pump is not all that hard to get working right and it does eliminate the quick stab hesitation, but (there's always a but) unless you run a twist throttle or you just make drag race runs, you better have a VERY stong thumb! The cable pull is radical for duning or all day riding. This may not work on everyones set-up but I have been successful with a 3/16 gap on the top screw (end of screw to white plastic cam) and adjusting the bottom screw to stop the stroke at 1/2 to 2/3 throttle.
Old Dec 4, 2002 | 02:49 PM
BIGBAJA's Avatar
I got the used 45mm from Marky's web site. My question is , I am planning on doing engine work in a few months (porting,cams,piston,springs)do I have to port my intake in order to use the 45mm carb right now, or should I just wait until I do the engine work to install the carb?
Old Dec 4, 2002 | 03:11 PM
KenDS's Avatar
No reason not to. MarkyNark is right in that you will have to rejet now and again after mods but otherwise no worries. Unless your a motorhead (like me and my buddies) I'm not in favor of changing too many things at once because troubleshooting can become much more difficult.
BTW, the stock intake manifold flows quite well on the flow bench and unless you do extensive head mods (porting, big valves, cams) you won't notice the difference, and from what I've seen on the bench, you may not even notice it after. Don't get me wrong, the ported intake is part of a system that complements the port work done on RWR stage III, but if your porting differs from that formula, save your money.
Old Dec 4, 2002 | 03:45 PM
  #15
jetsnow600's Avatar
i have a 45mm carb that i bought used and never put on. The little plastic piece is broken that holds the choke spring in, easy replacement. $250. Email me if u r interested [img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 4, 2002 | 11:14 PM
  #16
SANDMAN430's Avatar
i just had my stock intake manifold cleaned up, and it sure didn't line up well at all. we cleaned a lot out of the head also, so it seems if you don't do any work to the stock one the woods one wood be a good thing to have with the bigger carb
Old Dec 5, 2002 | 12:31 AM
  #17
BIGBAJA's Avatar
OK,next question- What jetting should I run? RWR says 150 main & 40 pilot. (What # needle ?)I have also been reading about the bogging problem.From what I have read a 3/16 gap on tha pump helps this. I also found out that you can install different jets for the accl. pump.What does everyone think?--Thanks for your help!!!
Old Dec 5, 2002 | 01:15 AM
  #18
ThePunisher's Avatar
Forget the pump!! Just run that setup they denf you and you will have no worries what so ever. Just ask anybody who has seen my bike run.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
