What Sprokets to buy?
Old Dec 4, 2002 | 09:19 PM
JSsDS's Avatar
Default What Sprokets to buy?
The wheel hub needs to come off to remove the rear sprocket and YES!!! the nut is tight. No match for an impact though. Front sprocket is even tighter and gave the inpact a work-out. I strongly suggest a dab of blue locktite on the nut and torque the sh*% out of it when you install it. Not sure what the torque is on that one, maybe somebody who has the manual can tell us[img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 4, 2002 | 09:49 PM
MudStud's Avatar
WOH!!!
I can take my front sproket off with a ratchet!!! Its a 3/4 drive and a shallow socket.. It got Like a 9-10 bar. It comes right off and on.. I have even rode with it.. Are you saying I need to get mine on tighter?? I orginally used an impact to get it off do i NOT have it on tight enough?
Got a web site for sidewinders???
Old Dec 4, 2002 | 11:42 PM
SANDMAN430's Avatar
the manual has a103ft.lb. on the front sprocket, the rear hub torque is173lbf9minimum
Old Dec 5, 2002 | 12:18 AM
albaBANSHE's Avatar
try sunstar sprokets
Old Dec 5, 2002 | 01:21 AM
  #15
ThePunisher's Avatar
Just get them from Ron Woods. Those other guy's want to much money! Of course they will last a little longer. If you don't want to replace your chain stay with the 15/42 combo. Actually I think this works a little better than the 15/43. And don't torque that back hub to 173 ft. lbs!!!!That is ridiculous!!! Put it at about 125 and you will be fine. You don't even tighten a Pinion nut on your 1 ton trucks differential that tight!!
Old Dec 5, 2002 | 01:45 AM
  #16
MudStud's Avatar
is 15/41 a vaild combo??? I want to to this for the 22 tires...
Old Dec 5, 2002 | 01:59 PM
  #17
JSsDS's Avatar
Here is a link tosidwinder
Old Dec 6, 2002 | 12:39 AM
  #18
FastYellow650's Avatar
ive got both sprockets form Sidewinder and the chain too. if and when i need another set ill probably go with them again
Old Dec 6, 2002 | 01:47 PM
  #19
JSsDS's Avatar
I too am happy with my Sidwinder chain and sprockets but I'm sure I could have saved some money buying them elswhere. Oh well no use crying over spilled milk. Quality costs money. You can't put a price on peace of mind.... bla bla bla...
Old Dec 9, 2002 | 07:01 PM
  #20
Uglyman32's Avatar
will i accomplish anything just going with a 15 front and leaving the rear alone?
