Building Motor
Old Dec 23, 2002 | 12:33 AM
glamisds650's Avatar
Default Building Motor
you can make your own rather inexpensively. 6" c clamp and notched pipe or pvc. you need further info let me know.
Old Dec 23, 2002 | 08:42 AM
FastYellow650's Avatar
thanks ill try out my fabrication skill out this morning
Old Dec 23, 2002 | 11:32 AM
glamis your little trick worked, now i have the springs off and installing the new base washers, do i leave the old one in and add the new ones, or do i take the old ones out, it looks like you need to leave the old ones in but not for sure,
thanks
Old Dec 23, 2002 | 01:01 PM
if the spring kit had new washers(spacers) remove the old ones and just use the new ones.
Old Dec 24, 2002 | 10:24 PM
  #15
i ran into an other problem, i was putting it all back together and a bolt broke, i got lucky thou, i was putting the cam carrier in a torquing them down and one of them snapped, but it broke off with a little above the head, and i was able to get it out, ill be ordering myself a set thursday
Old Dec 24, 2002 | 10:56 PM
  #16
Fourwheelphreek's Avatar
glamisds i was reading on your post that you made a compressor with a c-clamp and notched pipe. can you give me some more infor on this im in the process of removing my stock springs for new cams and dual rate springs. i have a 9" c-clamp already
dunerider
Old Dec 24, 2002 | 11:53 PM
  #17
Fourwheelphreek, you use the clamp with one side on the valve, the other side you want to use a piece of pvc or pipe with a cut-out on the side and clamp it down on the retainer. you use the access hole you drilled to remove the keepers once you remove the tension with the clamp. if you need a picture or need further explanation let me know.
p.s.use a cloth or something between clamp and valve so you don't mar the valve.
Old Dec 25, 2002 | 12:14 AM
  #18
thanx for the quick reply i figured it out and i already finished replacing the valves, now its on to bigger and better things! (piston,cams)
Old Dec 25, 2002 | 01:46 AM
  #19
RoostinOnYou's Avatar
better than the big socket trick on those hard springs[img]i/expressions/face-icon-small-smile.gif[/img]
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
mrtidy
Feb 3, 2016 05:00 PM
Whitelx1
Oct 2, 2015 10:55 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
