lowering a DS650 for Ice Racing
Old Jan 6, 2003 | 10:24 PM
Bellracing2's Avatar
Default lowering a DS650 for Ice Racing
jeffroe , where is verona ? Do you run with the swira club ? How have you done with the ds on ice ? What was the compatition like ?
Old Jan 7, 2003 | 10:52 AM
JEFFROE's Avatar
yes the swira club, lake wisconsin, bayview lodge, www.swiraclub.com. the competion is mostly 2 stroke shee's and 250r's they run hard!! last year i had a stageI rwr set-up and i did win a few heats but only if i got a real good hole shot. the shee's are so fast it's scary, but the TT racing is where you can make up for lost hp with good handling and even bigger ball's. i was running in the top 8 in points most of the season in both TT and oval til it got warm in feb i refuse to race on thin ice. there are some 4stroke only classes as well,come on out. where do you live?
Old Jan 7, 2003 | 11:00 PM
I'm in Antioch , Il I was going to try it this year but the money is getting tight . I might hit a few if I can.
Old Jan 12, 2003 | 12:42 PM
ScoobyDFW's Avatar
Originally posted by: BillDS650
You are going to have to make your own. You can get shorter shocks for the front and take out the short spring on the rear shock.
Will the short spring come off the end with the reservoir? Can you get the spring off without removing reservoir and having to refill nitrogen? Is the shock softer after removing this spring?
Old Jan 12, 2003 | 02:04 PM
  #15
BillDS650's Avatar
ScoobyDFW Eli54 did it for a flat track setup. He would have more info. I know he was having a problem with it eating the upper chain roller.
exmotocrosser
Sep 13, 2019 06:12 AM
Robinhood
Dec 26, 2015 10:28 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
