hot pami 760
Old Jan 6, 2003 | 06:01 PM
JEFFROE's Avatar
Default hot pami 760
anybody else running a pami760? want to see what cooling upgrades you have done? mine ran hot sunday out on the ice, still running my stock cooling system with no improvments. ran hot after running it hard for about 10-20min. not sure if maybe my head gasket is bad?
Old Jan 6, 2003 | 06:12 PM
biggerisbetter's Avatar
Jeff,
Are you running radiator shrouds??? they help alot.
Also you may be able to runn a cooler thermostat,Engine ice, and a toggle switch on your fan.
Biggerisbetter.
Old Jan 6, 2003 | 06:20 PM
JEFFROE's Avatar
thanks i did order shrouds and super cooler and water wetter today, doing a leak down test wed @ the dealer. today i warmed it up topped off the radiator reved it up watched for bubbles or cylinder pressure bleed back to the raditaor nothing, so i'm thinking the head gasket is ok, just want this sh*t to be over and ride the thing[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Jan 6, 2003 | 06:29 PM
Radiator shrouds will help ALOT, Before I put some on, My fan ran all the freaking time. Afterwards I ended up taking the fan off(didn't need it). Also running alky makes it run cooler also[img]i/expressions/face-icon-small-wink.gif[/img].
I also removed the rock shield from the radiator, since I only ride in the Sand I really dont need it.
Biggerisbetter.
Old Jan 6, 2003 | 08:17 PM
DSjockey's Avatar
It was running hot while ice racing? what was the air temp.? 30's? this dosen't sound like my 760, at Little Sahara in October (I think) ran to the top of the mountain several times, 500'-600' and never got over 200 even after the climbs
Old Jan 6, 2003 | 08:22 PM
SAMCOEDS's Avatar
SOUNDS LEAN TO ME make it richer it should cool down some.
Old Jan 6, 2003 | 08:31 PM
dsmike's Avatar
if you don't have a value sealing good it will run lean and hot. a cam shim might be to tight.
Old Jan 6, 2003 | 09:00 PM
JEFFROE's Avatar
it was about 34degs out, jetting ok checked plugs good color, not sure if i should still do leak down, no back pressure thru radiator, but remember this track is big! wide open thru all 5 gears, one down shift back up to 8500-9000 for about 10plus laps. at what temp does the light come on?
Old Jan 6, 2003 | 09:25 PM
jeffnrivercity's Avatar
The light will come on at 239 degrees and the fan switch activates at 203 degrees
Jeff
Old Jan 6, 2003 | 09:28 PM
JEFFROE's Avatar
jeff when you found you'r head gasket bad did you do the radiator pressure check (pressure feed back from leaking head gasket?)
