Does Anyone Make A Steel 42-Tooth Sprocket For The DS?
15-42 works with stock chain, are you sure you are getting you chain adjusted right, i saw a little wear on my aluminum sprocket, but the chain was to tight. i don't think i ride in anything but sand.
My brother put an aluminum sprocket on his 250R. It worked fine in the dirt. But after a week of hard riding in the sand, it was toast. I'm trying to avoid running into the same problem, and everyone with whom I've spoken has told me that sand + DS650 + big guy + aluminum sprocket = disappointment.[img]i/expressions/face-icon-small-shocked.gif[/img]
I have been running with 15/43 and an aluminum 43 tooth rear for about 9 months now and mine still looks like brand new! You just have to keep your chain tensioning right. And I have a used 42 tooth for sale if you want it , it is like brand new.
#18
seems like nobody wants to change the chain, whats up with that? new sprocket, old chain, won't that wear on the sprocket also? i bought a chain when i went to 15-43 there not that bad on price.
#19
If you get an aluminum rear sprocket make sure you get it heat treated. This will make it last longer. You get the aluminum sprocket to reduce the un-sprang weight. Now DuraBlue has an ultra high-tech aluminum sprocket hub that reduces Hub/Sprocket weight by half! Combine it with the heat treated aluminum sprocket you can save more weight and get more power to the ground.
#20
I can hardly believe that nobody out there makes a steel 42-tooth or larger sprocket for the DS650!!!!![img]i/expressions/face-icon-small-shocked.gif[/img] What's up with that?????[img]i/expressions/face-icon-small-disgusted.gif[/img]
