whats in your garage?
#1291
#1292
ds motor stage 2,ported and polished,new valve seats, exhaust valves. it will turn 13.5 to 13.9 on motor in the 1/4 mile. . ONLY RIDDEN AT THE TRACK..NOT MANY HOURS ON MOTOR!
ported intake w/thicker tab drilled and tapped with NOS nozzle.
holley NOS with everything incl. fuel pump
radiator SOLD
ron wood cdi
pep stabalizer- SOLD
gears 15,16,17 front 17 SOLD
gears 37,40,42 rear 37 SOLD
45muk/ with ron wood alcohol kit- SOLD
tranny with new plates and springs and new water pump seals and shaft.
cables clutch and throttle- SOLD
frame wrecked,but not cracked.
all wireing
trinity pipe and silender ..it has 2 stripped screws and bent hanger. real cheap
extra rims and tires to.
swingarm
brand new alpinestars tech8 10 mens -SOLD
shoei troy lee designs bright orangs green blue "picotte"$450 new. mens small full face
new stock springs. . . in the pack
stock bumpers front and rear
heal guards
stock intake stock pipe
stock piston
stock cams
stock valve and springs
stock cdi box
stock front shocks
stock rear shock
ignition.
coil
gas tank
drilled petcock for alky
oil tank SOLD
thumb throttle
gear lever
foot pegs
brake rotor
brake caliper
brand new in the pack,head gasket,base,valve gasket.
axle carrier
a-arms
front set of stainlees steel brake lines
brake resivor
530 oring chain. stock
axle anti -fade locknut
ds wheel hubs front and rear
kill switch
everthing will be stripped off the bike,so let me know what you need.
etc
radiator SOLD
ron wood cdi
all wireing
swingarm
heal guards
stock piston
stock cams
stock cdi box
stock front shocks
stock rear shock
ignition.
coil
gas tank
oil tank SOLD
thumb throttle
gear lever
foot pegs
brake rotor
brake caliper
axle carrier
a-arms
brake resivor
kill switch
etc
#1293
FOUND SOME MORE STUFF, ALL BRAND NEW IN THE BOX-
EXCEL DIRTBIKE RIM, SILVER 20X1.85
EXCEL DIRTBIKE RIM, SILVER 21X1.60
DG RED NERF BARS WITH RED NET FOR 300EX OR 250X
GENUINE YAMAHA CYLINDER HEAD FOR YZ426
GENUINE YAMAHA CYLINDER HEAD FOR YZ400
WISECO PISTONS KITS, MAKE ME AN OFFER FOR:
85-86 SUZUKI LT250 71.50MM
98-99 YAMAHA YZ125 54MM
94-96 YAMAHA YZ125 55MM
88-92 SUZUKI LT250 67MM
84-85 KAWASAKI KX80 48MM
73-75 YAMAHA RD350 +020 64.50MM
76-79 YAMAHA RD400 +020 64.50MM
KAWASAKI KX125 54MM
78-80 HONDA 250R 70MM
81-84 HONDA ATC 250R 70MM
YAMAHA BANSHEE 64.00MM PRO-LITE
YAMAHA WARRIOR YFM350
YAMAHA BANSHEE 64.00MM PRO-LITE WITH GASKET SET
KAWASAKI KX125 54MM
#1297
#1299
I know this is kinda the wrong Place to ask this.. But iknow some of you are X rider or have a banshee at home.. I am looking for a a good complete set of used banshee carbs.If you have a set collecting dust or know some one who does let me know could use them for my kids quad.... Thanks [img]i/expressions/face-icon-small-cool.gif[/img]
