whats in your garage?
#3021
#3022
#3023
Originally posted by: 650VIPER
Some things kicking around that gotta go.
2000 Ds engine, all or part. Head porting, shim unders, 14-1 piston, updated shift forks, clutch springs.
HPR ugly stick drag pipe.
JJ&A drag axle solid. Yamaha Hubs, honda sprocket.
Full set of Marvin Shaws. Front 17.5 eye to eye, rear I think 16 eye to eye but I need to check.
Boss Noss nitrous kit.
Drag front tires 6lbs.
520 conversion. x-ring chain, 14-42 sprockets. Rear sprocket is a honda pattern.
Ct Racing, custom cut drag pipe.
Most all these parts were bought new last season, and are in like new condition. All of them must go!
#3026
#3027
[quote]
Updated again.
Sorry Scott, no spare radiator!
2000 Ds engine case, crank, tranny, etc...
JJ&A drag axle solid. Yamaha Hubs, honda sprocket. I will take someones stock axle for y2k, with hubs in partial trade for this axle.
Updated again.
#3030
Btw stuff still in my garage.
04 stock swing arm
front brake calipers with good pads
front brake rotors
stock exhuast 04 ds
two stock cdi's one off an 03 baja the other off an 04 baja x
a-arm and chassis skids. Both stock from my 04 baja x (aluminium)
steel braided rear brake line for stock length swing arm.
Fairly new 530 chain for an 04 and newer length swing arms.
16 tooth front 530 sprocket
stock 40 tooth 530 rear sprocket.
Looking for a throttle cable for a lectron with a thumb throttle in my garage.
04 stock swing arm
front brake rotors
stock exhuast 04 ds
