whats in your garage?
#4101
<div class="FTQUOTE"><begin quote>Originally posted by: ERBEDS650
I'm also tripping on some ASR Adjustable (Camber/Caster) upper A Arms
These 4130 Chromoly Upper A-Arms replace the upper stock A-Arms and allow both Camber and Caster adjustment that you cannot get with the stock arms.
The Heim Style Ball Joint which has more travel than the stock one and allows the bike to turn much easier. This A-Arm to allow you to adjust the Caster on the bike to get it to turn properly!
The DS-650 suffers from not having enough positive Caster to turn and handle properly in tight situations.
This arm allows you to quicken or slow down the steering and also allows you to adjust Negative Camber into the front end so the tire does not roll over in hard turns.
These will be able to leave by Friday 10/03/2008</end quote></div>
Interested...need pics and cost shipped to 98662 Vancouver, WA. email: ericliz4@msn.com
Thanks
Eric
Thanks
Eric
#4107
#4109
