Combustion Analyzer data for a DS... Anyone have some?
Is that similar to the tool that you can buy from Summit? The thing from summit taps into your exhaust and measures air/fuel conditions to tell you if your running lean or rich. I thought about buying one of these tools aw well to simplify dialing in the carb.
Is Summit's a real-time reader (continuous) or does it take a one-time sample.
I may be able to use my portable boiler / burner analyzer for checking mine. I'll have to play around with it when I get back from my trip.
The only think is testing it at WOT where I the main jet is at. I need to have a load on the unit to get it to WOT otherwise I can red-line while sitting in the garage at mid throttle.
The unit I am using is a Kane-May KM9106. It's main purpose is to analyze the Flue on boilers and stuff like that. The one I have is in a case, but is battery operated (strap it to the back). I'm going to drill a hole in the head pipe were the two pipes come together and weld a bung on there (that way I can screw a cap in when finished). Mine reads in real time, with a data logger and a printer. Also comes with software for analysis on the computer.
I would like to compare data if you do the same thing. Interesting to see different setups and what really works the best. Combustion/exhaust analysis is a true reading on how well the engine is tuned.
08-06-2015 11:49 AM
