Taking out the axle???
Old Feb 17, 2003 | 01:33 PM
biggerisbetter's Avatar
Default Taking out the axle???
How do I do this???
I have got the sprocket off and brakes, but ther torx head bolts holding on the brake rotor are HARD!! Is thier a way to get them out?? I feel like I am going to brake the wrench.
After I get it off, what is the next step??
thanks,
Bigger.
Old Feb 17, 2003 | 02:27 PM
DuneDevil's Avatar
Hey Bigger,
As you are looking at the axle from the back, Take the left hub off (same side as the brake). Then tighten up the large nut that is pushing against the brake. Once that is tight, there is a "keeper ring" on the axle, it is under the big nut. Pry it off and remove it from the axle. Now remove the big nut. Then slide the brake hub off of the axle. Once the brake hub is off, you just slide the axle out.
If you want the brake hub off, You will have to heat up the Torx head bolts. They(Bomb) used some good stuff on them to keep them on!!!!
DuneDevil
Old Feb 17, 2003 | 09:00 PM
Cool! thanks man!
BIggersbetter.
Old Feb 18, 2003 | 12:47 AM
Hurycne's Avatar
I guess I need to know that too James![img]i/expressions/face-icon-small-wink.gif[/img]
1986Vmax540
Jul 9, 2021 09:53 PM
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 5, 2015 05:55 PM
toonces
Jul 28, 2015 01:58 PM
Rider252
Jul 6, 2015 03:37 PM
