tips for removing gas tank
Old Feb 18, 2003 | 02:31 PM
Razorcat's Avatar
Default tips for removing gas tank
I'm wanting to check the valve clearance on my '03 ds. As I sit and ponder this task, I think that removing the gas tank might be messy. Anyone have tips for removing it? All the guides for doing a valve check I have found just say "remove the gas tank" and don't explain it.
Old Feb 18, 2003 | 03:07 PM
02BAJA's Avatar
Turn the pet-**** to off, unhook the fuel line from the carb. Take out the four bolts that hold it on and take it off. You will loose very minimal amounts of gas.
Old Feb 18, 2003 | 03:11 PM
MudStud's Avatar
Ya, and dont blow up.
Old Feb 18, 2003 | 03:41 PM
Razorcat's Avatar
Would it be safe to smoke a cigar while I'm doing this?
J/K thanks [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 18, 2003 | 03:44 PM
MudStud's Avatar
Ya I would not smoke, you might singe those red nuts you got..[img]i/expressions/face-icon-small-smile.gif[/img] LOL Ok, thats enough.
Old Feb 18, 2003 | 06:21 PM
SANDMAN430's Avatar
don't forget to take the nose plastic off, and besure to get your quad good and clean before you start to go into the top end there. there are sites in here that give you the valve clearance, but seems i remember it being between .004-.006, just checked the manual and that is what it is. when i put the woods cams in mine elliote told me to go .006-.008, hope this helps
toonces
Jul 28, 2015 01:58 PM
cSchwartz
Jul 12, 2015 07:42 PM
cSchwartz
Jul 9, 2015 02:43 PM
Shifts
Jul 3, 2015 07:59 AM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
