Intake And Filter setup???
Old Feb 19, 2003 | 09:01 PM
Eaglecollector's Avatar
Default Intake And Filter setup???
Yea I am having the same problem with mine. I've tried shiming up the seat. But that hasn't worked. I think im going back to the filter in the box as well with no lid or snorkels. No dyno to check the results with though. So it will have to be field tested[img]i/expressions/face-icon-small-cool.gif[/img]
Old Feb 19, 2003 | 10:33 PM
biggerisbetter's Avatar
I cut out the problem. I cut out the metal(frame)brace that rubs the carb on the underneath. Just connect the holes, and cut them out.[img]i/expressions/face-icon-small-wink.gif[/img] Problem solved.[img]i/expressions/face-icon-small-smile.gif[/img]
Biggerisbetter.
Old Feb 19, 2003 | 10:42 PM
My problem is the seat rubs aginst the filter. How where you able to fix that? Do you use a filter that angles down more?
Old Feb 19, 2003 | 11:00 PM
DSWOLF's Avatar
k&n makes one that is 45degree angle so it rubs less,i put one small piece of duck tape on my outerwears,where it hits the seat,no more problem.....
Old Feb 19, 2003 | 11:21 PM
  #15
The filter bottoms out agianst the frame causing the seat to put pressure and rub holes, but when the frame is cut out the filter is more flexible and last alot longer.
BIggerisbetter.
Old Feb 20, 2003 | 12:02 AM
  #16
DDrecDS's Avatar
I modified my frame by heating up the filter area and bending it so it holds the filter and dosn't touch the seat any more. that was a good excuse to powdercoat it. I also ordered the K@N with the 5% bend.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Feb 20, 2003 | 12:23 AM
  #17
northjeepster's Avatar
Have any of you guys try a angled uni carb mounted filter?
Old Feb 20, 2003 | 01:17 AM
  #18
Hightower's Avatar
I have a brand new, never used, never oiled, 15degree carb mount Uni for whoever wants it - $10 and I'll ship! I bought a TM45 carb, won't work on it, so I have no use for it. PM me.
Old Feb 20, 2003 | 03:11 AM
  #19
why doesnt the 15degree uni filter work? seem to me it would work great
Old Feb 20, 2003 | 03:49 AM
  #20
Hightower's Avatar
It works great on the stock carb, and it does fit the TM45 bell, but the big collar that the filter has interferes with throttle travel. The throttle on this carb catches on the collar, and can stick open. Modifications could be made to avoid it, but I don't wanna.
