Intake And Filter setup???
Old Feb 19, 2003 | 05:15 PM
BIGBAJA's Avatar
Default Intake And Filter setup???
As some of you remember when I was at 4SW II I ran my bike on the dyno with two different air filter setups ( K&N carb mount and a Uni on the end of an intake tube 2-3/4" ID) Well the K&N carb mount made 4 more HP on top. My intake tube was about 15" long with a 2-3/4" ID opening on the carb side and tapers to a 3-1/2" opening on the filter mount side. I thought maybe it was the Uni so I orderd a TRX250R K&N clamp on filter ( This filter has a 4" opening) for the intake tube and tried it again. I am still losing top end HP[img]i/expressions/face-icon-small-mad.gif[/img]. Could it be I am getting more air and running lean or is the TM-45 made to run with a carb mount setup?Please Help!!!! Thanks..
Old Feb 19, 2003 | 05:21 PM
biggerisbetter's Avatar
Did you Dyno the 2 set-ups on the same day??
Biggerisbetter.
Old Feb 19, 2003 | 05:33 PM
BIGBAJA's Avatar
The 2 runs were about 3 mins. apart
Old Feb 19, 2003 | 05:41 PM
Is the snorkle intake in the airbox?? or is the filter in the open?? I would think the stock snorkle with an exposed air filter would be just as good if not better than a Carb mount filter.
Biggerisbetter.
Old Feb 19, 2003 | 05:45 PM
BIGBAJA's Avatar
It is a custom made snorkle (PVC) and the filter is out in the open.
Old Feb 19, 2003 | 05:53 PM
SoonerDuner's Avatar
Filter schmilter! I'm going to just run with no filter and see how fast I can go before the motor craps out![img]i/expressions/face-icon-small-happy.gif[/img]
Juuuuust kidding..
SD
Old Feb 19, 2003 | 06:35 PM
KenDS's Avatar
Check your jetting. K&Ns flow way better than foam filters, you are probably lean on top now.
Old Feb 19, 2003 | 07:16 PM
DSWOLF's Avatar
BIGBAJA i would like to know why you put your filter on the end of an intake tube,why not directly on the carb,just want to know..
Old Feb 19, 2003 | 08:13 PM
BIGBAJA's Avatar
Because the seat keeps rubbing holes in my carb mount. Also it helps keep my 45mm carb in place.
Old Feb 19, 2003 | 08:45 PM
Hightower's Avatar
Why the homemade tube - why not try the stock intake tube, with the airbox lid off and the snorkels removed? i know they collapse a little at high rpm, but you can help prevent that with large hose clamps places between every other rib of the intake tube. I'm just curious if it would make a difference.
You could also put a Uni filter direct on the carb - it wouldn't be hurt by the seat. just put some cloth tape at the rub points of the outerwear to keep from wearing holes in it.
