Where can I get a TDC bolt?
Old Feb 24, 2003 | 12:00 AM
MudStud's Avatar
Default Where can I get a TDC bolt?
I am looking for the specs on a TDC bolt? Should I get this from my dealer??
Any on have any extras??
Old Feb 24, 2003 | 12:14 AM
dsmike's Avatar
what bolt are you looking for? the one that locks the crank at TDC?
Old Feb 24, 2003 | 12:19 AM
Knutz's Avatar
Just get a long bolt from the hardware store and grind or file it to a dull point. It's not worth ordering from a dealer.
Old Feb 24, 2003 | 12:23 AM
Razorcat's Avatar
BMW part# - 90 88 6 116 570 TDC Crank Stop Bolt
You could make one or just have your dealer order one....I got this info from TDC Bolt FAQ
Old Feb 24, 2003 | 12:25 AM
MudStud's Avatar
Yea, for the crank..
I need to adjust my valves...
Knutz,, any bolt?? does it not require to be tapped???
How about just a long nail??
what is the proper way?? If it costs $ thats fine, i just want the right part.
Old Feb 24, 2003 | 12:28 AM
Knutz's Avatar
It's a metric machine bolt. I believe it's 5MM, but I'll have to check on that. I can't remember off the top of my head what the exact specs are, but I'll find out. I know you can pick them up at Lowes or Home Depot for pennies, and not have to waist time ordering.
Old Feb 24, 2003 | 12:31 AM
MudStud's Avatar
Thanks Knutz I will wait for the specs then get it right the first time..
Old Feb 24, 2003 | 12:34 AM
dsmike's Avatar
if i remember right one of the bolts that hold the skid plate on will work. you have to grind it to a point.
Old Feb 24, 2003 | 12:35 AM
Knutz's Avatar
The wait is over, 8MM!
Get one about 40MM long or so. That will be more than long enough. It has to be about 25MM at the shortest, but too long is no problem at all.
Old Feb 24, 2003 | 12:42 AM
MudStud's Avatar
so ..
8mm
1mm tap
MIN 25mm long..
Right???
