Building a Faster DS- don't tell the rappy guys!
Old 03-17-2003, 11:58 PM
nytephyr's Avatar
Default Building a Faster DS- don't tell the rappy guys!
what he says about the smaller ports makes sense. ever used a blower to help start a fire? when i was a kid my dad had a fireplace made out of a 55 gallon oil drum in his workshop. he had a two inch pipe stuck in the bung hole for a vent. I learned early on that if i started a fire and left the door open it would take a while to get going. however, if i closed the door and left the vent open the fire created enough suction that the vent turned into a blower and accelerated the fire. it think the same thing happens with the smaller ports, the intake suction brings more air/fuel in faster and under more preasure that with larger ports.
  #22
Old 03-18-2003, 12:21 AM
Majorecho's Avatar
Demon- did you read issue#22- that is the $50K championship winning race engine tear down- it uses pistons with a single sealing ring- for less friction - but sealed beautifully. Pami knows how to build their stuff!
  #23
Old 03-18-2003, 12:34 AM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
Yes i haed a ronwoods stage III with the blowbye problem i did not let it bother me no problem[img]i/expressions/face-icon-small-happy.gif[/img]
  #24
Old 03-18-2003, 12:38 AM
Hightower's Avatar
Does JE make all Pami pistons? I have what I'm told is a piston from Pami, made by JE, and it has 2 comp rings and an oil ring, like the norm. What's this about Pami's having a single compression ring?
  #25
Old 03-18-2003, 12:45 AM
AZSAND's Avatar
the stroker's have one ring and oil ring ! the rest are normal[img]i/expressions/face-icon-small-confused.gif[/img]
  #26
Old 03-18-2003, 02:29 AM
DemonDS's Avatar
I havent read that one yet but i will now for sure. I always end up reading them all like 3 times to make sure i get it all.
rcappie4
07-18-2015 07:51 AM
HondaR24
07-16-2015 10:45 AM
Robinhood
07-13-2015 09:13 PM
Dirtbikemike1
07-11-2015 03:36 PM
Edgeslade
Where to Ride
07-10-2015 05:08 PM
Quick Reply: Building a Faster DS- don't tell the rappy guys!
