Just finished my TM45 tuning
Old Mar 28, 2003 | 03:30 PM
  #31
DSHawk650's Avatar
Default Just finished my TM45 tuning
Hightower, I took the plunge and ordered the TM45 today. Found a brand new one on Ebay. Sending the money order in a few minutes. I am sure I will be talking to you about it. Glad to hear that you are getting yours dialed in. Good riding to you. Hawk
Old Mar 28, 2003 | 06:44 PM
  #32
Forcefed's Avatar
when your holding the football - people will throw evrything they can at you to strip it away .... including the waterboy at the end of the bench.
Got mine off Ebay too....when you get it there are a few things that will need to be done to make it ready. Choke cable, plug off the two vents on the front of the carb, lighter return spring if your staying with the themb throttle, and jetting of course. Mine came set-up for a Harley, with a 20 pilot, #97 needle (I think), and a 135 main, ect....
Old Mar 28, 2003 | 06:59 PM
  #33
Hightower's Avatar
hey guys, about the choke - you can install the choke assembly off the stock carb onto the new TM45, it fits perfectly and correct. you just gotta lift the seat to reach it each ride.
The carb from RW costs more, $400 I think, because they also fit it with an extended collar on the front to make more clamping surface, and it fits exactly in place of the stock carb, perfectly trapped between the intake manifold and the intake tube coming from the airbox. if you wanna go carb mount filter and elliminate the intake tube, the bigger clamping surface is very handy to help keep the carb from coming off. they might sell you this collar, if you want it.
regardless how you mount it, you need to port the intake to match - roughly 1.5mm needs removed from inside radius. round files and emery cloth are all that's required, die grinder and cutting bits ideal, or have a local shop do it more like $20. taper it back a good 1/2" and you're good to go.
Old Mar 28, 2003 | 11:08 PM
  #34
DSHawk650's Avatar
Hey Hightower, the collar that you are talking about, is it on the head side or the air cleaner side. I am running a carb mount filter.
Old Mar 29, 2003 | 08:49 AM
  #35
Hightower's Avatar
Its on the head side, bringing it back out from under the tank cover a little more, but nothing done to the rear of it where you clamp the filter.
Johnny Mac
Aug 15, 2019 03:13 PM
kbazzy
Sep 26, 2015 11:26 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Elkaholic
Sep 6, 2015 02:44 PM
