rocky mountain sprockets
Old Apr 10, 2003 | 12:08 AM
SANDMAN430's Avatar
Default rocky mountain sprockets
well i want to try a 14 front and not knowing if i would like it or not, i ordered two from rocky mountain they were like 12.99 each well when i opened the box i could tell right away that they weren't as clean cut as the ones i got from alba the alba ones were around 30 each. but other than that they seem to be as thick in every way and should do the trick. well i'll let you know how it works.
Old Apr 10, 2003 | 12:48 AM
MudStud's Avatar
I use the rocky mountain sprokets also
I have the 14 Titax
I have the 15 No namer
Ok the Titax is just as thick but its teeth are not a rounted or angled on the sides
The 15 or rocky mountains no namer is actually made by Renthal. I like the looks of the 15 as its teeth sides are rounder but both sprokets perform just fine.
Old Apr 10, 2003 | 02:17 AM
DSRTRCR's Avatar
Got my 15t from RM today. "Primary Drive" brand name.
Tried it on. Then tried on the one that I received from TVI a week ago.
TVI unit was somewhat more $$.
TVI unit is installed, RM unit will be returned.
Too much spline play for my liking.
My opinion only, your's may differ.
$$ difference in sprocket cost vs. $$ for output shaft = no brainer.
buddieboy
Dec 9, 2016 05:50 PM
MooseHenden
Family ATVing Photos
Oct 5, 2015 08:14 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
merryman
Sep 19, 2015 03:15 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
