new 45 carb. help
Old Apr 12, 2003 | 06:45 PM
gixer's Avatar
Default new 45 carb. help
throttle is very stiff and it is bogging on take off. what can i do?
Old Apr 12, 2003 | 08:58 PM
DSHawk650's Avatar
Ron Wood makes a lighter throttle return spring for the 45. You are not suppose the use the accel pump when you use this spring. It really helps on the thumb throttle. Most guys are using a pilot jet between a 40 to 45 and a main jet from 150 to 160 with any where from 1 1/4 to 2 turns out on the air screw.
Old Apr 14, 2003 | 10:34 AM
SANDMAN430's Avatar
try using the stock cable, the bog is not there at 160, no pump, other than that they sell those little hand springs that you can use to work out while you drive in the car
wendal
Oct 31, 2017 03:31 AM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Sassinm1
Sep 30, 2015 04:23 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
