Random stalling...sup with that??
Old May 1, 2003 | 12:39 AM
DSDuneCrazy's Avatar
Default Random stalling...sup with that??
I agree, it sounds like your engine is loading up.
-Tom
Old May 1, 2003 | 01:03 AM
dunesled's Avatar
check your head pipe nuts to make sure they're tight. When mine come loose it coughs, sputters and dies and I know it,s time to retighten. Someday I will get smart and buy some loctite and get rid of that damn recurring headache!!
Old May 1, 2003 | 09:57 AM
SANDMAN430's Avatar
i think it is now ds.net now and buttfungus has a chart with where everyone has there machines jetted. i run a 170 in the stock one with a woods pipe, it might take a 180 ok but it seems to work fine.
Old May 1, 2003 | 12:51 PM
TyreSpinner's Avatar
Okay, i'll check out the plugs when I get the chance, and if the problem persists, I'll have someone check it or i'll try to fix it myself.
Also, i forgot to mention, sometimes, while riding on lower gears or in neutral...at less than 1/4 throttle, I pin the throttle WOT, and sometimes, instead of screaming, the engine just like skips a beat (oddly as it sounds), the engine doesn't stall or anything, it just like, skips a beat...Only way I can explain that...It does not do that every time. Happened twice...could this also be due to generous jetting??
Thanks
Old May 1, 2003 | 01:28 PM
  #15
CrazyWhiteDude's Avatar
yea I would say definitely check the jetting
Old May 1, 2003 | 05:29 PM
  #16
Would taking off the airbox lid help??
Maybe let it breathe a little better..dunno
what do you guys think?
Old May 1, 2003 | 06:18 PM
  #17
biggerisbetter's Avatar
good idea, if you are running rich, that willl help, and atleast let you know if you need to re-jett.
Biggerisbetter.
Old May 1, 2003 | 06:26 PM
  #18
Alright, I'll try taking it off...
I guess with the lid off, mud and water will get in there like a fly on a decaying corpse right?
I'm running a K&N filter in the stock airbox without an outerwear.
Has anybody had problems with water getting in there with the lid off?? Thanks.
Old May 1, 2003 | 06:34 PM
  #19
racerx5x5's Avatar
Yea,what's the poop? Has any one seen that outerwear cover on e-b##?
Old May 1, 2003 | 06:44 PM
  #20
markdf's Avatar
Just a suggestion before you go changing jets etc. Drain the float bowl first. It might be something as simple as a tank of bad gas with water sitting in the bottom of the float bowl.
Mark
