New Sunl 90 Won't Start?
Old Feb 25, 2006 | 10:18 AM
randan's Avatar
Default New Sunl 90 Won't Start?
I just put my son's new Sunl 90 togehter and it won't start. It turns over fine but doesn't seem like it's getting any fuel?
Any ideas would be greatly appreciated....... Today is his birthday and I would really like for hom to be able to ride it.
Thanks
Old Feb 25, 2006 | 01:29 PM
rodneygt's Avatar
You will probably need to bleed the brake in order for it to work. I did.
I had to adjust the carb in order to get my daughter's started. There are some instructions on that in various posts. - Generally close the mixture screw then open 1 1/2 to 2 turns to get it running. Set idle. You may have to let it idle for about 1/2 hour - I'm told there is a gel pac in the carb that must dissolve. Then can make final adjustments.
Rodney
Old Feb 25, 2006 | 01:31 PM
rodneygt's Avatar
Oh, the tether plug is often defective too. If you disconnect it from the wiring harness (unplug the electrical connector) it wont cut spark.
Old Feb 25, 2006 | 04:36 PM
randan's Avatar
I got it started! The fuel filter was on backwards and it wouldn't allow any fuul to pass through. I had to bleed the brakes alot to get them to work but finally got it.
Thanks for your help!
Old Feb 25, 2006 | 07:26 PM
RacewayATV's Avatar
randan I am happy everything worked out for you! Sorry we are not in on Sat and Sun!
And rodneygt thanks for the help! Sounds like you saved a b-day! People like you make these forums so great!
Raceway ATV
MikeyBoyesq
Nov 27, 2020 02:44 PM
Bigredjeep
Apr 10, 2020 02:55 AM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
